Error when Setting a Theme with Telerik Controls
 I get this error when setting the telerik:StyleManager.Theme property in my Silverlight App:
Error: Sys.InvalidOperationException: Invalid XAML for control 'SilverlightMapConnector1'. [] (line 25, col 30): The attachable property 'UpdateTextOnEnter' was not found in type 'TextBoxBehavior'
Is this a ThinkGeo issue or a Telerik issue?
Hi Josh,
It’s hard to tell whether this issue comes from Telerik:StyleManager or MapSuiteSilverlightEdition just by the error message you mentioned. However, after searching the error message, I found someone else raised a similar issue on Telerik forum. This link will redirect you to the thread and hope you can get an answer there.
telerik.com/community/fo...8-dev.aspx
Also you can provide us further information about the name and version of the telerik control you’re using in your application, so that we can have a look at this issue.
Further questions please let me know.
 Thanks.  I'll check it out.
If your problem won’t be resolved please let us know so that we can assist you further.
