Error With Track Shape Finished
Hi All,
My Map has the following
    <cc1:Map ID="Map1" runat="server" Width="100%" Height="100%" MapUnit="Meter" OnTrackShapeFinished="Map1_TrackShapeFinished">
            </cc1:Map>
Now that works great for when my users draw a Point on the map.
But when they draw a polygon i get the following error:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.5.21022; .NET CLR 3.0.30729; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E)
Timestamp: Mon, 6 Jun 2011 13:35:30 UTC
Message: Sys.WebForms.PageRequestManagerServerErrorException: Target Shape Is Not Valid Type.
Line: 938
Char: 13
Note i have the following Code inside:
   Protected Sub Map1_TrackShapeFinished(ByVal sender As Object, ByVal e As EventArgs)
            Dim MapKeyId As String = "map1"
            Dim SelectedMap As ThinkGeo.MapSuite.WebEdition.Map = DirectCast(Me.FindControlRecursively(MapKeyId), ThinkGeo.MapSuite.WebEdition.Map)
            Dim lastPoint As Feature = SelectedMap.EditOverlay.Features(SelectedMap.EditOverlay.Features.Count - 1)
            Dim textRadiusName As String = "txtRadius"
            Dim textRadius As TextBox = DirectCast(Me.FindControlRecursively(textRadiusName), TextBox)
            Dim ellipse As EllipseShape = New EllipseShape(lastPoint, Double.Parse(textRadius.Text))
            SelectedMap.EditOverlay.Features.Add(New Feature(ellipse))
        End Sub
Hi Gregory,
 When you new an EllipseShape, the first paramter should be a PointShape or a feature from PointShape.
 Here your lastPoint is not a point, so we will throw this exception for tell you we cannot build an EllipseShape from a polygon.
 You need to make a simple shape type validation before build the ellipse, or you can just change your code like this:
 Dim ellipse As EllipseShape = New EllipseShape(lastPoint.GetBoundingBox().GetCenterPoint(), Double.Parse(textRadius.Text))
 This way will have a new ellipse use your polygon center as center point.
