Just curious do you really want to display 300 points and 4000 geodetics at the same time, seems too many for one screen.
About the performance, we have tested with WorldMapKit, for showing about 100 cities, 800 roads and 800 polygons(Counties or Zip Polygons), we need 2~3 seconds for every refresh, including fetching data from shape files and displaying on Desktop. I’m not very sure about the Postgre, I think with index enabled, it should be fine.
It will be easy to implement: create a timer and refetch / redraw the data every 5 seconds. One thing to be aware is that you can add the above shapes to DynamicOverlay and every 5 records, just redraw those features by calling map.RedrawDynamic().
Also please have a look at the samples within Querying Feature Layers, where you can find how to perform the operations.
This is the general way how to do it. Please feel free to let me know if you have some detailed question about the implementation.
We don't support those formats. But if you are familiar with that, it's very easy to create your own layer and support them in Map Suite. Here is a webinar which shows how to extend the Map Suite for Microsoft Access, which we don’t support internally. Here is the link where you can find the video, the slides, and the source code.
