We are creating an AVL system and I'm evaluating the Map Suite Web Edition for a while. I just wanted share my thoughts with you.
I find the product very powerful and well designed. I've checked through the samples and saw that the product does what ever I wanted to do with ease, and some. It has a capable and detailed API, which I'm sure will serve us very well.
I've also read literally hundreds of messages in these forums and found most of the answers I'm looking for. I can not help but notice, that ThinkGeo support is very knowledgeable, patient and extremely helpful. I've seen a lot of cases, that support people even provided the complete working solution.
With some other companies, normally you would expect to pay handsomely for this level of support. Most of the time you would get 'Use this class' or 'Call this function' or 'I'm perfectly sure it is something YOU have done, the product is fine' blah, blah.
We are working on a very tight time schedule and it is very important to know that if I'm stuck somewhere, I can depend on your help to resolve the issue.
As a result, good product and good support make the Map Suite the perfect fit for our system.
ThinkGeo, please keep up the good work. Customers / prospective customers do appreciate it very much.
Hakan Çelik
