I have a problem in my application, so i produced a sample application and it still has the problem. The vertex added event fires four times for the first vertex and than fires normally. Is it possible to not fire it so many times the first time? I also have this problem in the track ended event. If i do some edits and than use the track ended event it fires multiple times. Here is the code attached.
I have a gridview to display the edit vertices, but i get more vertices than the existing ones
Sample.txt (1.96 KB)
