Exception "The input double value is out of range."
Hello!
I still try to find value settings for CurrentExtent and CurrentScale.
Can you please test with the attached sample and tell me why the one set of CurrentExtent values (which are commented out) just works while the other (not commented out currently) throws an exception when I try to load that page?
I simple want to pre-defined the region that appears in the map. I don’t find any example for this.
Karsten
my_sample.zip (851 Bytes)
I just learned that I applied the Parameters in a wrong sequence. So problem is solved! Thanks
Hi Karsten,
 I am glad to hear that solved.
 Any question please let us know.
