Hi Steve,
You’re right that ExecuteQuery was dropped from ShapeFileFeatureLayer. The original implementation read the .dbf companion through System.Data.OleDb with the Microsoft.Jet.OLEDB.4.0 provider, which is for Windows-only and doesn’t exist on .NET Core +, so we removed it during the cross-platform migration from v12.
You can subclass ShapeFileFeatureSource and wire OleDb back in for a Windows-only project, but the deployment story is rough: Jet 4.0 was never built for x64, and the 64-bit alternative (ACE 12.0) needs every end-user machine to have the Microsoft Access Database Engine Redistributable installed at the matching bitness. The only “no-install” path is forcing x86, with the 32-bit address-space ceiling. Most
customers can’t accept that anymore.
So converting the dbf data to a standard DataSet is not a bad idea. Also ThinkGeo.Gdal exposes the .dbf through OGR with its own SQL engine, you can try that as well if you already using gdal in the project.
var layer = new GdalFeatureLayer(@"places.shp", "places");
layer.Open();
DataTable dt = layer.QueryTools.ExecuteQuery("SELECT * FROM places WHERE POP > 50000");
