ExecuteScalar issue
I have a Shapefile layer that I want to query a value from.
Dim
 CntyLayer As New ShapeFileFeatureLayer(MAPLayersPath + "\" + COUNTYBORDER_LayerFile)
Thanks , Madduri
CntyLayer.Open()
Dim layerName = System.IO.Path.GetFileNameWithoutExtension(COUNTYBORDER_LayerFile)Dim CntyName = CntyLayer.QueryTools.ExecuteScalar("SELECT " & CountyName & " FROM " & layerName & " WHERE " & CountyCode & "=" & RoadwayCounty)
CntyLayer.Close()
I keep getting the following error:
The Microsoft Jet database engine could not find the object 'County_Boundary'.  Make sure the object exists and that you spell its name and the path name correctly.
The sql query evaluates to:
"SELECT CNTY_NAME FROM County_Boundary WHERE CNTY_CODE=1"
I have checked that the dbf file and shp files exist in the path. Also the layer appears correctly on the map. What am I doing wrong here?
Madduri,
 Thanks for your post and question!
 We tried the code with a different data, and it works fine. So I doubt the data you are using is the reason for this problem, could you send me your data for this?
Attached zip file contians the data.
Thanks for your help.
-Madduri
1136-County_Boundary.zip (91.6 KB)
Madduri,
You missed the .shx file :). Could you upload the corresponding .shx file?
Madduri,
 We found that root reason for this problem, the length of the file name should be less than 8 characters. It seems that OLEDB does not support it.
 You can rename it to Boundary.shp or something.
Thank you. Really appreciate you looking into this.
I have implemented a workaround for this issue. I was able to use the find features containing method to get the value I need. It worked out in the current situation, but I will check file name length if I have to query for a value in the future.
Regards
madduri
Madduri,
 Thanks for letting us know your status!
