Export different projection map to PDF
   Using example code I am able to export all  map layers to PDF. It looks fine in PDF. When I printed the same pdf mercator and wgs84 projection maps came correctly. Problem came with Lambert conformal conic projection. Print shows pixels only. Please suggest what could be the problem.
Thanks & Regards,
Goral
Hi Goral,
 I tested that in our UsePdfExtension sample, everything looks correct, please test that use my test code as below in your end:
 private void CreateASpatialIndexForAShapeFileLayer_Load(object sender, EventArgs e)
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"…\SampleData\Data\Countries02.shp");
            worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.StartCap = DrawingLineCap.Round;
            worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.EndCap = DrawingLineCap.Round;
            ManagedProj4Projection proj4 = new ManagedProj4Projection();
            proj4.InternalProjectionParametersString = ManagedProj4Projection.GetDecimalDegreesParametersString();
            proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(2154);
            proj4.Open();
            worldLayer.FeatureSource.Projection = proj4;
            worldLayer.Open();
            winformsMap1.CurrentExtent = new RectangleShape(-357823.2365, 7230727.3772, 1313632.3628, 6037008.6939);
            staticOverlay.Layers.Add("WorldLayer", worldLayer);
            winformsMap1.Refresh();
   Thanks for reply. I will check and get back to you.
Thanks & Regards,
Goral
Any questions, please feel free to let us know.
