Hi, I'm trying to use a postgis table instead of a shp file to story my roaddata.
(postgres 9.2.2, postgis 2.0.1) npgsql 2.0.12
I'm using this sample: C:\Program Files (x86)\ThinkGeo\Map Suite Routing Full Edition 6.0\HowDoISamples\CSharp HowDoISamples\CSharp Desktop HowDoISamples\Samples\ExtendingRoutingSource.cs
But Im getting this exception: {"ERROR: 42883: function st_asbinary(integer) does not exist"} when i get to this line: Feature feature = featureSource.GetFeatureById(roadId, ReturningColumnsType.NoColumns);
Here are something I cannot confirm for your issue: I have a postgis table named “rail” and the column name of feature is “oid”. In psogreSQL, I use the below string to query when get feature by id, can you check it on your table to make sure the string or your table is correct?
“select st_asbinary("shape") from "rail" where "oid" in (‘1’);”
And I use the below code to do the work of postgis in postgre, it works well on desktop edition. can you check the code on your environment?
