I’m using the built-in ExtentOverlay functionality to draw an extent to zoom into. However, I’m noticing the left and right sides of the extent get cut off when zoomed in. I attached an example gif. In it, I first placed a rectangle on the map to use a reference. I then use the ExtentOverlay tool, and you’ll see that after it zooms in, the margins for the top/bottom look fine but the left/right get cut off. Is there a reason for this?
Using version 12.0.
