Here is a good question...I think. What is the quickest way from a sql search to getting the bounding box on a feature. I am doing this currently on a large database so it is fast to do the SQL search but slow to return the Feature. I am sure there is a faster way to do this but not totally sure what that is. Here is an example of what I am doing:
DataTable dataTable = worldLayer.QueryTools.ExecuteQuery("Select * From"); worldLayer.Close(); List<DataRow> list = dataTable.AsEnumerable().ToList(); var staticOverlay = (LayerOverlay)Map1.CustomOverlays["StaticOverlay"]; var spatialQueryResultLayer = (InMemoryFeatureLayer)staticOverlay.Layers["SpatialQueryResultLayer"]; worldLayer.FeatureSource.Open(); Collection<Feature> spatialQueryResults = worldLayer.QueryTools.GetFeaturesByColumnValue("LABEL", list.ElementAt(0).ItemArray.ElementAt(4).ToString()); worldLayer.FeatureSource.Close();
I try to test your code but it looks the dataTable.AsEnumerable().ToList(); met error here. So could you did a test in your environment, add some stopwatch to make sure which line takes most time when you operate a big shape file. I think the result should be helpful to locate the problem.
The portion of code that is very slow is this: worldLayer.FeatureSource.Open(); Collection<Feature> spatialQueryResults = worldLayer.QueryTools.GetFeaturesByColumnValue("LABEL",list.ElementAt(0).ItemArray.ElementAt(4).ToString()); worldLayer.FeatureSource.Close();
This bit of code grabs the feature after you know which feature to grab…
What I would like to know is how to get the bounding box from a sql search? What is the quickest method to do this? Is it the method I presented above?
Thanks for your response, I don’t know why but the .ToList(); and .ElementAt(0). cannot pass compilation in my vs2010.
Your worldLayer should be a InmemoryFeatureLayer and it really will so slow when did spatial query even than you get all items from shape file?
Because we don’t have a better way to get boundxing box from sql search, so I want to make sure that, maybe we can find the reason and optimize it so that imporve the speed.
I suggest you directly get all features then add them to InmemoryFeatureLayer, build index for this layer, then did all query works on it. I think that should more faster.
I have been working with something similar. 2 things that seemed to speed things up for me:
Instead of pulling the static layer, which for me is my feature layer from Map1.StaticOverlays, I just redeclare a new ShapeFileFeatureLayer.
I found that GetFeaturesById is faster than GetFeaturesByColumnValue, and it allows you to grab multiple features at once. I simply added the id as a column in my sql tables. The id is the native primary key, and is faster, at least it was for me.
