Fatal Exception on VertexMoving's Cancel
 Scenario:
signing up _map.EditOverlay.VertexMoving += EditOverlay_VertexMoving
and when Canceling the move, exception happens.
void EditOverlay_VertexMoving(object sender, VertexMovingEditInteractiveOverlayEventArgs e)
            try
                //Debug.WriteLine("VertexMoving");
                if (!_map.FullExtend.Contains(e.TargetVertex))
                    //_logger.Error("The point is outside of the map extend. Canceling move.");
                    e.Cancel = true;
            catch (Exception ex)
                _logger.Error(ex);
System.NullReferenceException was unhandled
  HResult=-2147467261
  Message=Object reference not set to an instance of an object.
  Source=WpfDesktopEdition
  StackTrace:
       at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass2.<DrawException>b__0()
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
       at System.Windows.Threading.DispatcherOperation.InvokeImpl()
       at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Windows.Threading.DispatcherOperation.Invoke()
       at System.Windows.Threading.Dispatcher.ProcessQueue()
       at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
       at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
       at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
       at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
       at System.Windows.Application.RunInternal(Window window)
       at System.Windows.Application.Run()
       at APP_PSD.App.Main() in C:\Projects\Main2\Projects\Implementation\Apps\APP_PSD\obj\x64\Debug\App.g.cs:line 50
  InnerException:
PLEASE ADVICE. This is the basic way of using Cancel feature.
System: version: 6.0.0.0, runtime: v2.0.50727.
Hi Croft,
 Thanks for your post, we have fixed this bug, please get the 6.0.261.0 or 6.0.0.261 and have a try.
 Edgar
Edgar, thank you.
 Where can I find the release notes on 261. I downloaded WpfDesktopEditionFull6.0.0.261DllPackage.zip and there are not release notes.
 We are having some other issues, ThinkGeo would just crush with not stack leading to it, happens occasionally.
 And I was wondering if this kind of issues were observed by others and fixed in latest patch. Thank you.
Hi Croft,
 There is no release note in every patch, but in the major release we have a list about the release information.
 Could you please tell us how did you get the exception above? A sample would be great and helpful.
 Edgar
