Hello Support Team,
we are facing one issue on FDOExtention(PersonalGeoDatabaseFeatureLayer). below is my configurations of Machine and
OS:- windows 8 64 bit
Microsoft Office :- 2010 (32 bit)
I have move below mention folder to Windows/System32 and Windows/SysWOW64 folders.
1. To use MapSuiteFdoExtension win32 version on 32bit system, please copy folder “MapSuiteFdoExtensionx86” to system32 folder.
2. To use MapSuiteFdoExtension win32 version on 64bit system, please copy folder “MapSuiteFdoExtensionx86” to systemWOW64 folder.
3. To use MapSUiteFdoExtension win64 version on 64bit system, please copy folder “MapSuiteFdoExtensionx64” to system32 folder.
Now, If I am running my Application at x64 bit configurations and I have follow about step-3 for same. see attachement(system32.png). but still i am getting below error
{"Connect failed: Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver (*.mdb);DBQ=C:\Connecticut\newingtonAnnotation.mdb,\n[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified"}
While If I am running my application with x86 bit configurations it will working fine.
Can you tell me what should be solution for this issue ?
Eric
FDO Extention Not working on 64 bit machine
Hi Eric,
Warm welcome to Map Suite Forums!
Your issue description is very clear and I think the issue is happened because the odbc 64 bit is required but your office is under 32 bit. So in order to use this feature in x64, please download and install the AccessDatabaseEngine_x64.exe. We can download it from here: microsoft.com/en-hk/down…x?id=13255
If the issue persists, don’t be hesitate to let us know.
