What is the easiest way to programatically add a tooltip like effect to a feature? For instance I have a lineshape that I want to display a tooltip when the user hovers over the line. Same goes for polygons and multilineshapes...e.g., I was thinking of something like this:
Dim multilineShape As MultilineShape = CType(BaseShape.CreateShapeFromWellKnownData(mLineTxt), MultilineShape) 'Would like to do something like this: multilineShape.Tooltip = _myTooltipText Dim feature As New Feature(multilineShape)
'Or...Would like to do something like this: feature.Tooltip = _myTooltipText Dim MyinMemoryFeatureLayer As New InMemoryFeatureLayer MyinMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.CreateSimpleLineStyle(clr, lineWidth, False) MyinMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 MyinMemoryFeatureLayer.InternalFeatures.Add(feature) LinesOverlay.Layers.Add("SF_LineLayer_" & i.ToString, MyinMemoryFeatureLayer)
Thank you for your post and idea, but sorry to say, we only allow to set tooltip to a feature in 2.x version, for now popup or tooltip is not allowed to add to a feature. This feature is supposed to be added to a layer overlay (be added to a layer first and then add the layer to a layer overlay).
But there is a sample that can show you how to add tooltip to a layer, I hope it can help you.
The margin is arbitrary, but I stuck the label in the middle of the map for now.
Then in the mousemove:
Private Sub WpfMap1_MouseMove(ByVal sender As Object, ByVal e As System.Windows.Input.MouseEventArgs) Handles WpfMap1.MouseMove Dim worldPointShape As PointShape = ExtentHelper.ToWorldCoordinate(WpfMap1.CurrentExtent, New ScreenPointF(e.GetPosition(WpfMap1).X, e.GetPosition(WpfMap1).Y), WpfMap1.ActualWidth, WpfMap1.ActualHeight) Dim MyOverlay As LayerOverlay = DirectCast(WpfMap1.Overlays("MyOverlay"), LayerOverlay) Dim showTooltipTolerance As Double = 0.1 For j = 0 To MyOverlay.Layers.Count - 1 Dim MouseChkBox As New RectangleShape(worldPointShape.X - showTooltipTolerance, _ worldPointShape.Y + showTooltipTolerance, _ worldPointShape.X + showTooltipTolerance, _ worldPointShape.Y - showTooltipTolerance) Dim bitmapLayer As InMemoryFeatureLayer = MyOverlay.Layers(j) Dim crossed As Boolean = False For i As Integer = 0 To bitmapLayer.InternalFeatures.Count - 1 If MouseChkBox.GetDistanceTo(bitmapLayer.InternalFeatures(i), GeographyUnit.DecimalDegree, DistanceUnit.Mile) <= showTooltipTolerance Then crossed = True Next If crossed Then lblMouseOver.Margin = New Thickness(Border2.Margin.Left + e.GetPosition(WpfMap1).X _ , Border2.Margin.Top + e.GetPosition(WpfMap1).Y _ , Border2.Margin.Right - e.GetPosition(WpfMap1).X _ , Border2.Margin.Bottom - e.GetPosition(WpfMap1).Y) lblMouseOver.Content = "some content" lblMouseOver.Visibility = Visibility.Visible Else lblMouseOver.Visibility = Visibility.Hidden End If Next End Sub
Then I did not need the tooltip class and the performance seem great. I had the map inside a border (border2) with no margin between the map and the border:
I was looking through the forum to find how to put in tooltips and thankfully found this example.
Is there any plan to integrate this functionality into WpfMap natively?
Personally, I think that it is a fundamental service that needs to be there and I would rather not write it in myself if it is planned to be integrated in some release.
Thanks for your post, sorry to say that we don’t support “feature tooltip” for now. You can vote this enhancement to helpdesk.thinkgeo.com/EnhancementTracker. This captures the enhancement request and provides visibility to the customer letting them know that the enhancement is on a list somewhere and that popularity of the enhancement helps set the priority of when the enhancement would be added to the product. This option doesn’t carry any cost for you.
Or if you need this function immediately, your account rep can contact you for a professional services.
Another thing is that there is an elevation place in Micheal’s solution. In Wpf_MouseMove() we could add a timer, and move the code to the timer and let the timer to do the work, that way we don’t need to do the work every time the mouse moves.
As I use the above code for a large number of polygons (20k +), I was getting impacted by performance due to iteration. So I modified the code to:
PrivateSubWpfMap1_MouseMove(ByValsender AsObject, ByVale AsSystem.Windows.Input.MouseEventArgs) HandleswpfMap1.MouseMove DimimfLayer AsInMemoryFeatureLayer = CType(wpfMap1.FindFeatureLayer("MyIMFL"), InMemoryFeatureLayer) IfimfLayer IsNothingThenExitSub'No layer exists so exit 'Define bounary in pixels aroun poygon to trigger tooltip DimscreenBuffer AsInteger= 5 'Maintain buffer at any zoom level DimcurrentPointF AsNewScreenPointF(e.GetPosition(wpfMap1).X, e.GetPosition(wpfMap1).Y) DimbufferPointF AsNewScreenPointF(currentPointF.X + screenBuffer, currentPointF.Y) DimdistanceBuffer AsDouble= ExtentHelper.GetWorldDistanceBetweenTwoScreenPoints(wpfMap1.CurrentExtent, currentPointF, bufferPointF, wpfMap1.ActualWidth, wpfMap1.ActualHeight, wpfMap1.MapUnit, DistanceUnit.Meter) 'Make sure there are features IfimfLayer.InternalFeatures.Count > 0 Then 'ToWorldCoordinate requires a column name, so just use a dummy or a real name if there is one DimcolumnNames AsNewList(Of String)() columnNames.Add("dummy")
Dimfeatures AsCollections.ObjectModel.Collection(Of Feature) DimworldPointShape AsPointShape = ExtentHelper.ToWorldCoordinate(wpfMap1.CurrentExtent, NewScreenPointF(e.GetPosition(wpfMap1).X, e.GetPosition(wpfMap1).Y), wpfMap1.ActualWidth, wpfMap1.ActualHeight) SyncLockimfLayer 'Lock the layer while opening it imfLayer.FeatureSource.Open() 'Get features within the buffer zone distance features = imfLayer.FeatureSource.GetFeaturesNearestTo(worldPointShape, wpfMap1.MapUnit, 1, columnNames, distanceBuffer, DistanceUnit.Meter) imfLayer.FeatureSource.Close() EndSyncLock Iffeatures.Count > 0 Then'We got some features Dimf AsFeature = DirectCast(features(0), Feature) 'We are only interested in the first one Dimmoc AsMyOwnClass = DirectCast(f.Tag, MyOwnClass) 'Get the instance of MyOwnClass from the Tag property tblMouseOver.Text = moc.TooltipText 'Set the TexBlock text to our tooltip text
Thank you very much for your sharing this, this will be also helpful to other customers who meet similar problem. And if you have any more question , please feel free to let us know.
