FeatureLayerWpfDrawingOverlay and LineDashStyle
It seems that from some reason LineDashStyle does not take effect when used with FeatureLayerWpfDrawingOverlay. Lines are always drawn with solid line even if e.g LineDashStyle.DashDot is used in style. This can be re-produced e.g by changing LayerOverlay to FeatureLayerWpfDrawingOverlay in Render lines example on HowDol.
Is this intentional or a bug ?
Br, Simo
Hi Simo,
It’s not intentional, we’ll fix it in the near future.
Thanks for the info. Is there any workaround available to get it working with 14.4.5 ?
Br, Simo
Hi Simo,
We’ve just fixed it in the latest beta (v15.0.0-beta049), can you give it a shot?
I’m afraid it cannot be worked around in v14.4.5. We can add this fix to the next hotfix release (v14.5.2, by the end of this month) if you need it.
Yes, it’s now working with latest beta.
It would be great if you could add this fix to coming v14.5.2. Thanks in advance !
Br, Simo
Hi Simo,
V14.5.2 is available on NuGet. This fix is included, and here is the changelog: Changelog - ThinkGeo Docs
