I've run into a very puzzling mystery. When zoomin in on certain features in the map, they disappear !
To make things more complicated, it happens in a web application run by Map Suite, fetching WMS images from another web application run by Map Suite. The data are read from a SQL server 2008 spatial database.
Please feel free to view the solution here: hvmgo01.hvenegaard.dk/MEGOTEST/
First zoom into the area designated by the red square:
Then turn on the features layer, and notice the two areas marked by red squares.
Turn the background layer of to see the features layer more clearly (it's 50% transparent, hence the faded colors):
If one zooms into the top square area, all's well, and you can zoom as much as you like. However, if one zooms into the lower square area, all features disappear when reaching the next-to-lowest zoomlevel. You can then pan upwards, and they'll reappear at some point.
What can cause such puzzling behaviour ? Is this a problem within the OpenLayers client ?
Tried it with both IE9 and FF10, but both exhibit the same problem.
TIA
