File Geodatabase Support?
I saw the recent support of Personal Geodatabases, and have utilized that in my application. I'd also like to use a File Geodatabase (which, to my knowlege, is very similar to the Personal Geodatabase, except it stores the data in separate files, rather than one mdb file). The differences between the Personal and File Geodatabases can be seen at this page: webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Types_of_geodatabases
In essence, structure is the same, I just need a class to instantiate that will form the FeatureLayer using the geodatabase directory instead of a single mdb file. I know this is FDO stuff, so if anyone can point me in the right direction I'd really appreciate it!
Kevin,
Thanks for your interests in Map Suite component.
I am sorry to say that we probably cannot support the File Geodatabase up to now. The reason is that the FDO only support the OGR vector format mentioned below:
gdal.org/ogr/ogr_formats.html
Thank you for clearing that up Yale.
Kevin,
 No problem.
 Let me know if any more questions.
