Hi Morten,
In fact the loading image is usually used for web based version, for local version the loading speed is so fast so we don’t need it.
If you found a shape file is loading slow, please
- Build index for it
- Open cache for the overlay
- Adjust your render logic to make sure you don’t render too many shapes at the same extent
But if you have a scenario you want to load a totally new shape file and which will make the UI looks not responding, I think you can implement that your self.
You can draw a static image on map when you tried to load a shape file, for example you can set a special overlay which contains a LogoAdornmentLayer, then you can use this layer to display a static image
When you start load a big shape file, you can show the overlay by your event
When the shape file loaded succeed, you just need hide this, you can implement that by some event like overlay.Drawn
Wish that’s helpful.
