FileGeoDatabase in v12
FileGeoDatabaseFeatureLayer seems to have changed significantly in v12.
For example, there is no GetTables function and the layer no longer has a way to set which TableName you want to display on the map.
How do we work with this layer in v12?
Damian
Thanks Damian,
In V12 FileGeoDatabaseFeatureLayer we don’t have the GetTables API now because in the V12 we will use a different way to do this. We are still working on adding it back. We will let you know once it available.
Frank
