Greetings
Im currently using thinkgeo web edition 6.0 and im trying to find the intersection between two polygons but i cant get around the idea to code it just yet can you help me with that.
Regards
    Greetings
Regards
Hello saddam,
 Thanks for your post, I think you can refer this sample:
 wiki.thinkgeo.com/wiki...tersection
 Let us know your queries.
Greetings
i tried the link but its not working, what im loking for is a code that will get a polygon out of a series of llat and long and then compare it to another polygon from another set of lat an long.
thanks
Hi saddam,
I have fixed the link but I am not sure we understand your needs. Could you offer some additional explanation on what your end goal is?
A couple of resources that might be helpful:
Our QueryTools method that can has various options to help you compare features to one another. wiki.thinkgeo.com/wiki/Think...QueryTools
You will see we have a GetFeaturesIntersecting option that might work for your case.
Our Clipping sample application could be helpful if you want to clip a polygon out of a group of polygons:
wiki.thinkgeo.com/wiki/Map_S...s#Clipping
Hi Ryan
The problem im trying to solve is that i have several pieces of land which i have their bounderies in lat and long each of them make a polygon and i need to check if any of them intersect with another.
thanks alot
Hi saddam,
 I believe the GetFeaturesIntersecting would be the best method to get back what features are intersecting your existing feature.
