Find out in which polygon the mouse click falls into
1)I have a layer with some polygons (i.e us states) i want to click somewhere in the  map and in return i would like to get the polygon that the point falls in (within)
2) if i  find out from the above question that the point belongs to the polygon with id=5
how can i get the coresponding name of the polygon
i.e the shp file of the us states has the columns id, name, shape ...
Thanks in advanced
dimitrs
We have a sample in the "How Do I" sample apps that shows exactely how to do that. It is the sample "Get Data when User Clicks" in the "Querying Feature Layers" section. In this sample, we are using countries of the world. For the US states it would work exactely the same way.
Yes you are right this is exactly what i want to do.
Should always search for the answer first in the Samples its just that sometimes i forget
Thanks for your quick reply
Dimitris,
 The samples show the features we have provided for uses. If you get accustomed to it; you will find what you want with ease. Also, if you have any problem; welcome to discussion forums.
 Khalil
