hi
actually i am working on an asp.net project in which i am displaying a map of a country only. there are two drop down lists from which user will select the name of feature i.e a new york and from other dropdown list , user will select the data to populate on that farticular feature on the map. for example ppopulation, i want to change the color of that particular feature depending upon some conditions, on the map. hope you understand what i want to say.
i studied documentation on mapsuite and its web samples, and now i'm able to display a simple map. i have some questions...
1. i want to ask that how can i findout the name of the feature when customer column fetch event is fired, as it gives the id and column name only. i need to know its name also . as i am new mapsuite user so please suggest me some solution.
2. how can i zoom to a particular feature giving by user from dropdown list.?
3. how can i change the fill color of that feature only..?
i have studied your mapsuite web samples. they helped me a lot.
please help me as soon as possible.
