First time load slow w/lots of disk activity
Using DesktopEdition 4.5, we notice the first time we render a map using the World Map Data Kit it takes about 30 seconds to display the map. During that time, there is significant disk I/O happening (visible via perfmon). Later renders of the map, even after stopping and restarting the application, do not take long at all (< 5 seconds). After the machine is rebooted, the first load will again take > 30 seconds.
Any idea why? I can understand reading the data from the shapefiles, but I'd like to understand what is happening the first time the map is loaded after the machine boots that is different from subsequent loads of the control.
Thanks for any insight,
pk
Paul,
 I have tested WorldMapKit with “CS VS2010 DesktopEditionSample” but with no luck, every time I load map costs pretty much the same time no matter first load or restart application or reboot machine. So I am afraid you might modify some code to cause the problem, if it’s could you provide which code you modified, or you may need to provide more information to help us recreate your problem.
