Forcing Server-Side Layer Redraw when Using CallbackRequest and CustomColumnFetch
Hello!
This is something that has been bothering me for a few months.  I had a temporary solution but it is time to optimize the speed of our mapping application, so I want to see if you guys can help with a better solution.
Here is the situation:
I have a map which uses Callback Requests to change stuff on the back end.  But after the Callback Request returns, and I call the OpenLayers API redraw( ) method, it doesn't work.
My dilemma is that if I call Generate_Map( ), it works.  But this is a VERY SIMPLIFIED example.  I have about 20 other layers on my map, and Generate_Map( ) has to reload all of them.  Is there a way to do something the way Refresh_Map( ) works.  It seems like it is just ignoring me every time I tell it to Redraw( ).
public partial class __Default : System.Web.UI.Page, ICallbackEventHandler
Map tgMap; //This is only here for the sample code... In reality this is defined in the ASPX file...
Dictionary<string, string> zipTerritory = new Dictionary<string, string>( );
protected void Page_Load( object sender, EventArgs ea )
if ( !IsPostBack )
ZipTerritory_Load( );
Generate_Map( );
protected void ZipTerritory_Load( )
SqlDataReader sqlDataReader = new SqlDataReader( );
Some code has been removed for brevity where  sqlDataReader" is loaded with data!
zipTerritory.Clear( );
while ( sqlDataReader.Read( ) )
zipTerritory[sqlDataReader["Zip"].ToString( )] = sqlDataReader["Color"].ToString( );
protected void Generate_Map( )
ShapeFileFeatureLayer zipShape = new ShapeFileFeatureLayer( /* ... Omitted ... */ );
zipShape.FeatureSource.CustomColumnFetch += new EventHandler<CustomColumnFetchEventArgs>( Zip_CustomColumnFetch );
ValueStyle zipTerritoryColor = new ValueStyle( "TerritoryId", new Collection<ValueItem>( ) );
zipTerritoryColor.ValueItems.Add( new ValueItem( "1", new AreaStyle( new GeoSolidBrush( GeoColor.StandardColors.Red ) ) ) );
zipTerritoryColor.ValueItems.Add( new ValueItem( "2", new AreaStyle( new GeoSolidBrush( GeoColor.StandardColors.Red ) ) ) );
zipTerritoryColor.ValueItems.Add( new ValueItem( "3", new AreaStyle( new GeoSolidBrush( GeoColor.StandardColors.Red ) ) ) );
zipShape.ZoomLevelSet.ZoomLevel01.CustomStyles.Add( zipTerritoryColor );
zipShape.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
LayerOverlay mainOverlay = new LayerOverlay( "Main", true, TileType.MultipleTile );
mainOverlay.Layers.Add( "Zip", zipShape );
tgMap.CustomOverlays.Clear( );
tgMap.CustomOverlays.Add( mainOverlay );
protected void Zip_CustomColumnFetch( object sender, CustomColumnFetchEventArgs ea )
FeatureSource zipShape = (FeatureSource) sender;
Feature zipFeature = zipShape.GetFeatureById( ea.Id, ReturningColumnsType.AllColumns );
string zipCode = zipFeature.ColumnValues["ZIP"];
if ( ea.ColumnName.StartsWith( "TerritoryId" ) )
ea.ColumnValue = zipTerritory[zipCode];
private string callbackResult = "";
public string GetCallbackResult( )
return callbackResult;
public void RaiseCallbackEvent( string callbackRequestString )
string[] data = callbackRequestString.Split( new char[] { '|' } );
string zipCode = data[0];
string territoryId = data[1];
zipTerritory[zipCode] = territoryId;
SqlCommand cmd = new SqlCommand( /* ... */ );
cmd.Execute( string.Format( "UPDATE SET territoryId = {0} WHERE zip = {1}", territoryId, zip ) ); //SIMPLIFIED EXAMPLE
Generate_Map( ); // THIS WORKS, but I am starting from SCRATCH.  SUB-OPTIMAL.
But would prefer to do to this:
Refresh_Map( ); // Would prefer to simply NUDGE the server to refresh only what I need
public void Refresh_Map( )
LayerOverlay layerOverlay = (LayerOverlay) tgMap.CustomOverlays["Main"];
ShapeFileFeatureLayer layer = (ShapeFileFeatureLayer) layerOverlay.Layers["Zip"];
layerOverlay.Redraw( ); // DOES NOT WORK
layer.FeatureSource.GeoCache.Clear( ); // DOES NOT WORK
function LayerRedraw( name, callback )
var l = OpenLayersMap.getLayer( name );
if ( l )
if ( l.mergeNewParams )
l.mergeNewParams( { 'version' : Math.random( ) } );
l.redraw( );
I didn't include the part which shows the callback, because you've seen the code many times already, most likely.  Here it is just in case.
function SwitchTerritory( zip, territoryId )
function MapRefreshCallback( result, refreshCallback )
LayerRedraw( "Main" );
var state = zip + "|" + territoryId; //Move Zip
WebForm_DoCallback( '__Page', state, MapRefreshCallback, null, null, true );
I'm pretty sure the problem is not with my script.  There's something going on the back-end that is causing the server to ignore me.
So I’m debugging in Visual Studio and it looks like when I set the Dictionary’s value in the Callback, it isn’t getting picked up by the other threads, since ThinkGeo is using multithreading to render the tiles.
No answer so I went at it alone with a crazy hack.
I figured when the threads were being created, the Map object was being passed to each one.  So I created a dummy FeatureSource I could use.
public class AlignmentDataLayer: FeatureLayer
public AlignmentDataLayer( IEnumerable<FeatureSourceColumn> featureSourceColumns )
this.FeatureSource = new AlignmentDataSource( featureSourceColumns );
public class AlignmentDataSource: InMemoryFeatureSource
public AlignmentDataSource( IEnumerable<FeatureSourceColumn> featureSourceColumns )
: base( featureSourceColumns )
public Hierarchy Hierarchy = new Hierarchy( );
public StringDictionary TerritoryZip = new StringDictionary( );
public Collection<Style> CustomStyles = new Collection<Style>( );
Now, from my C# code-behind, I can place arbitraty properties into this so they get passed around with the map. It's ugly but it works better than having to refresh the whole map.
public Hierarchy ScenarioHierarchy
get
return Alignment.Hierarchy;
protected StringDictionary ZipZone
get
return Alignment.TerritoryZip;
public AlignmentDataSource Alignment
get
LayerOverlay dataOverlay;
AlignmentDataLayer dataLayer;
if ( Map.CustomOverlays.Contains( "Data" ) )
dataLayer = (AlignmentDataLayer) ( (LayerOverlay) Map.CustomOverlays["Data"] ).Layers["Data"];
else
dataLayer = new AlignmentDataLayer( new Collection<FeatureSourceColumn>( ) );
dataOverlay = new LayerOverlay( "Data", false, TileType.SingleTile );
dataOverlay.IsVisible = false;
dataOverlay.IsVisibleInOverlaySwitcher = false;
dataOverlay.Layers.Add( "Data", dataLayer );
Map.CustomOverlays.Add( dataOverlay );
return (AlignmentDataSource) dataLayer.FeatureSource;
Hi Abner,
 Sorry I reply you late, your post come in our best busy day.
 I remembered if call redraw in openlayers, you need add a bool value as the parameter, like layerOverlay.Redraw(true);
 Could you have a try that?
