Full version still showing unlicensed
I have a full version which when deployed on other machines shows unlicensed.  How do i get rid of this?
TIA.
Klaus,
 The unlicensed should not be in the full version when deployed on other machines. Could you show us the version number and make sure the cache files are cleared?
 Howard
Howard, looks like the problem is me.  I was using eval version 4.0.104.0.  So you can consider this solved.  However, I created another thread with a white screen when using full version.
Hi Klaus,
 That’s fine. For the other thread about the white screen; we tested in Win2007 and 2008 with our How Do I samples using the same version 4.0.108; but it works fine. So could you go to that post and show us a simple sample to help us create your issue?
 Howard
