Generating TextStyle type at runtime
Hi
I am using following function to read and generate PointSymbolType at runtime.
It works absolutely fine.
        private PointSymbolType GetPointSymbolType(string sAccessPointSymbolType)
            string[] sEnums = sAccessPointSymbolType.Split('.');  //PointSymbolType.Circle
            string typeName = sEnums[0];
            string enumValue = sEnums[1];
            Type type = core.GetType(String.Format("{0}.{1}", nameSpaceForCore, typeName));
            PointSymbolType returnType = (PointSymbolType)Enum.Parse(type, enumValue);
            return returnType;
How do I read and generate TextStyles.City1("LABEL"); at runtime.
I tried following code but not getting any idea how to get right one.
        private TextStyle GetTextStyle(string sTextStyleType, string sDisplayColumnName)
            string[] sEnums = sTextStyleType.Split('.');  //TextStyles.City1("Label");
            TextStyle returnType = (TextStyle)Enum.Parse(type, enumValue);
            return returnType;
City1 and Display Column name needs do be read at runtime. As user can change this value
Hiren
Hiren,
The following code helps you to get the text style.
public static TextStyle GetTextStyle(string methodName, string columnName)
            Type type = typeof(TextStyles);
            MethodInfo method = type.GetMethod(methodName);
            TextStyle style = (TextStyle)method.Invoke(null, new object[] { columnName });
            return style;
Howard
Howard,
Thanks for quick reply. I will try and update you
Hiren
Hiren,
 No problem. Let me know if you have any questions.
 Howard
