According to the documentation, one of the overloads for DrawArea takes, as its first parameter, IEnumerable<ScreenPointF>. However, when I actually try to use this function, it appears to want IEnumerable<ScreenPointF[]> (A collection of ScreenPointF arrays).
Which is correct, and, if it's the latter, what data is expected in the first parameter?
The first parameter of this API is an Innumerable of an item which is an array of ScreenPointF. In this way, it will stands for an area in the screen.
Following sample code snippet is a way to recreate it: ScreenPointF screen1 = new ScreenPointF(1.0f, 1.0f); ScreenPointF screen2 = new ScreenPointF(1.0f, 2.0f); ScreenPointF screen3 = new ScreenPointF(2.0f, 2.0f); ScreenPointF screen4 = new ScreenPointF(2.0f, 1.0f); ScreenPointF[] screenPointFs1 = new ScreenPointF[] { screen1,screen2,screen3,screen4};
ScreenPointF screen6 = new ScreenPointF(3.0f, 3.0f); ScreenPointF screen7 = new ScreenPointF(3.0f, 4.0f); ScreenPointF screen8 = new ScreenPointF(4.0f, 4.0f); ScreenPointF screen9 = new ScreenPointF(4.0f, 3.0f); ScreenPointF[] screenPointFs2 = new ScreenPointF[] { screen6, screen7, screen8, screen9 };
Collection<ScreenPointF[]> colScreenPointF = new Collection<ScreenPointF[]>(); colScreenPointF.Add(screenPointFs1); colScreenPointF.Add(screenPointFs2);
I'm using the canvas it to draw points with a custom rotation and color showing vehicle direction and status for a tracking application.
I actually ended up not using that verion of DrawArea. I want the point shape to stay a consistent size at all zoom levels so I'm calculating the basic shape using screen points (10 pixels wide, 15 pixels high, for example). Then I convert those points to world coordinates using ExtentHelper, put the points in a polygon shape and rotate that. Works fine.
