GeoCanvas Drawing with Screen Coordinates
I have an older program I’m trying to upgrade from v10 to v12. It has some custom layers and styles that I was drawing on the map. I was performing all my calculations in screen coordinates and then using GeoCanvas.DrawLine(List…) to draw my shapes on the map. In v12 it looks like I can only draw using world coordinates now. Is that correct, or am I missing something else? Do I really need to convert a ScreenPointF to a PointShape via ToWorldCoordinate, and then back into a ScreenPointF to use with DrawLine?
Tim
Hi Tim,
Which specific version are you using? I checked the source code of v12.0 and the latest version v12.3.10.4, and I found that DrawLine supports screen points, the fifth overload is the one you need.
DrawLine(IEnumerable<ScreenPointF> screenPoints, GeoPen linePen, DrawingLevel drawingLevel, float xOffset, float yOffset)
Leo
OK, I figured it out. I was converting to screen coordinates the wrong way. Once I started using MapUtil and canvas.CurrentWorldExtent, everything worked as expected.
Thanks for taking a look!
Hi Tim,
You’re welcome. I’m glad your problem was resolved. Let me you know if you have more questions.
Leo
