GeoCollection.Remove(string) API does not seem to work
Guys,
Looks like the GeoCollection.Remove(string) API does not work.   I modified your sample AddSimpleMarkers class to be able to remove a marker as follows:
using System;
using System.Linq;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Media.Imaging;
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.WpfDesktopEdition;
namespace CSHowDoISamples
    public partial class AddSimpleMarkers : UserControl
        public AddSimpleMarkers()
            InitializeComponent();
        private void WpfMap_Loaded(object sender, RoutedEventArgs e)
            wpfMap1.CurrentExtent = new RectangleShape(-155.733, 95.60, 104.42, -81.9);
            WorldMapKitWmsWpfOverlay worldMapKitOverlay = new WorldMapKitWmsWpfOverlay();
            wpfMap1.Overlays.Add(worldMapKitOverlay);
            SimpleMarkerOverlay markerOverlay = new SimpleMarkerOverlay();
            wpfMap1.Overlays.Add("MarkerOverlay", markerOverlay);
            wpfMap1.Refresh();
        private void wpfMap1_MapClick(object sender, MapClickWpfMapEventArgs e)
            if (e.MouseButton != MapMouseButton.Left) return;
            SimpleMarkerOverlay markerOverlay = (SimpleMarkerOverlay)wpfMap1.Overlays["MarkerOverlay"];
            Marker marker = new Marker(e.WorldLocation);
            marker.ImageSource = new BitmapImage(new Uri("/Resources/AQUA.png", UriKind.RelativeOrAbsolute));
            marker.Width = 20;
            marker.Height = 34;
            marker.YOffset = -17;
            var contextMenu = new ContextMenu();
            var menuItem = new MenuItem();
            menuItem.Header = "Remove";
            menuItem.Name = "Marker" + marker.GetHashCode().ToString();
            menuItem.Click += OnRemoveMarkerRequested;
            contextMenu.Items.Add(menuItem);
            marker.ContextMenu = contextMenu;
            marker.Name = menuItem.Name;
            markerOverlay.Markers.Add(marker);
            markerOverlay.Refresh();
        private void OnRemoveMarkerRequested(object sender, RoutedEventArgs e)
            var markerOverlay = (SimpleMarkerOverlay)wpfMap1.Overlays["MarkerOverlay"];
            var markerName = ((MenuItem) e.Source).Name;
           // does not work?
            markerOverlay.Markers.Remove(markerName);
            var marker = markerOverlay.Markers.First(m => string.Compare(m.Name, markerName, StringComparison.OrdinalIgnoreCase) == 0);
            markerOverlay.Markers.Remove(marker);
            // remember to unhook MenuItem from OnRemoveMarkerRequested
If you run the sample, an exception is not thrown by the LINQ statement indicating that the marker was not removed.  However, grabbing the marker instance and remove it works correctly.  Any ideas or a better recommendation on how to remove markers?
TIA.
W
Never mind, figured it out.  Needed to add markers to GeoCollection<T> using the Add(string, T item) API instead of the Add(T) API.
Hi Klaus,
 Glad to hear the problem is sorted out, if you have any other question, please feel free to let us know.
 Summer.
