Geographic Coordinates
Hi
I am using sample code GPStoGoogleMap from the given link
wiki.thinkgeo.com/wiki/Map_Suite_Desktop_Edition_Background_Maps_(Google,_Bing,_etc)_Samples
my question is I cant see coordinates in geographic format at mouse move event on status bar. Infact I tried some projection menthod from Internaltoexternal and externaltointernal converstions. But not works. I need to see coordinates in Decimal degee / degree minutes seconds. Kindly mention the code that need to convert.Thanks
Zeeshan
ZEESHAN,
I update the same code to show how to display decimal degree coordinates
        private void winformsMap1_MouseMove(object sender, MouseEventArgs e)
            //Displays the X and Y in screen coordinates.
            statusStrip1.Items["toolStripStatusLabelScreen"].Text = "X:" + e.X + " Y:" + e.Y;
            //Gets the PointShape in world coordinates from screen coordinates.
            PointShape pointShape = ExtentHelper.ToWorldCoordinate(winformsMap1.CurrentExtent, new ScreenPointF(e.X, e.Y), winformsMap1.Width, winformsMap1.Height);
            proj4.ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
            proj4.InternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
            proj4.Open();
            pointShape = proj4.ConvertToExternalProjection(pointShape) as PointShape;
            proj4.Close();
            //Displays world coordinates.
            statusStrip1.Items["toolStripStatusLabelWorld"].Text = "(world) X:" + Math.Round(pointShape.X, 4) + " Y:" + Math.Round(pointShape.Y, 4);
It might has performance issue because MouseMove event will be raised frequently, you could define Proj4Projection object as a module variable and open it at form_load, don't close until form closed.
Thanks it is working
 Zeeshan
Zeeshan,
 I am glad it’s working with you.
 Feel free to let me know if you have more questions.
