GeoImage DefaultPointStyle
I am trying to get images to display for points on a layer however I am having some difficulty getting the images to load.  I have pasted the code below that I am using to render the images.  I am having problems as it seems the .png format is not accepted.  This is the exception that I receive:  image Parameter name: The input GeoImage object is not a valid GeoImage type.  Can anybody see what I am doing wrong?
Here is the code:
ShapeFileFeatureLayer layer = new ShapeFileFeatureLayer(Application.CommonAppDataPath + "\\" + shapeFileName + ".shp", ShapeFileReadWriteMode.ReadOnly);
layer.RequireIndex = false;
layer.ZoomLevelSet.ZoomLevel14.DefaultPointStyle.PointType = PointType.Bitmap;
layer.ZoomLevelSet.ZoomLevel14.DefaultPointStyle.Image = new GeoImage(Assembly.GetExecutingAssembly().GetManifestResourceStream("EPIC.Works.Resources." + assetType.AssetTypeResource));
// Create and set zoomlevel.
layer.ZoomLevelSet.ZoomLevel14.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Map.StaticOverlay.Layers.Add(layer);
Curtis
Got it, not sure what the issue was but it seems to be resolved now.
 Curtis
Curtis,
 Thanks for keeping us updated.
 Your code seems fine; just one small suggestion is that we don’t recommend setting the RequireIndex to false. It is fine if for a simple test; but for a real application, using the index file will greatly improve the performance.
Ben,
Thanks and that is what it was there for, a simple test.  Was trying to figure out what was wrong with another issue.
Curtis
Curtis,
 That’s fine. Let us know for any more queries.
