GeoImage from embedded resource
I created a project that uses DesktopEdition.dll file. I added a bitmap file to my project and i can get it by calling "Properties.Resources.Image1". I want to show a point style in my map control with the added image. I look at the GeoImage constructor and it only takes path, stream or well known data. How can i create a geoimage wtih an embedded image resource?
Thank you
Hi Onur,
 Thanks for the post, would you please try the following code? It should be helpful
            MemoryStream stream = new MemoryStream();
             Properties.Resources.Image1.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
             GeoImage geoImage = new GeoImage(stream);
             layer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(geoImage);
 Hope it helps,
 Edgar
Thank you for the sample, it works.
Best regards
Onur
You’re welcome Onur, if you have any questions please let us know.
 Edgar
