Hi when i get to this: var ftshape = item2.GetShape();
I get this exception…
System.ArgumentException : The format of the well known binary is incorrect.
Parameter name: wellKnownBinary
---- System.NotSupportedException : Geometry Type 3006 is not supported now.
What have i done wrong? :) I have just imported the shp file (that was working) into postgresql, and changed from ShapeFileFeatureLayer to PostgreSqlFeatureLayer and then I get that exception?!?
//ShapeFileFeatureLayer sf = ServiceRouting.ShapeLayerHelper.GetShapeFileLayer(_shpFile);
PostgreSqlFeatureLayer sf = new PostgreSqlFeatureLayer (Utils.Connections.Connectionstrings.GetSqlConnectionPG(), "zonep", "gid");
FeatureLayer _feature = new InMemoryFeatureLayer();
List<string> columns = new List<string>(); </string></string>
columns.Add("price");
sf.Open();
var _featuress = sf.QueryTools.GetAllFeatures(columns);
sf.Close();
_feature.Open();
_feature.FeatureSource.BeginTransaction();
foreach (Feature item2 in _featuress)
try
How to fix? (Or is Geometry Type 3006 going to be implemented into PostgreSqlFeatureLayer ?)
- Niels
Geometry Type 3006 is not supported now ? PostgreSqlFeatureLayer
Hi Niels,
Can you please send us your sample and the shape file? It’ll be easy to recreate your scenario.
Edgar
Hi I have uploadet the shp fileto ftp://ftp.thinkgeo.com/ filename:postgres3006.zip
The code that works with the file but not when using postg. is …
public static FeatureLayer GetZoneLayer(string countryShortIsoName)
if (countryShortIsoName.ToUpper() == "DK")
// It works as shp file but not after import to postgresql 9.1 using postgis 2.0
// string _shpFile = @"C:\GisData\t2\PriserTilPriceTool_01-SWi_region.shp";
PostgreSqlFeatureLayer sf = new PostgreSqlFeatureLayer(Utils.Connections.Connectionstrings.GetSqlConnectionPG(), "zone_price_dk", "gid");
sf.Open();
sf.Close();
_feature.Open();
try
var ttt = item2.ColumnValues;
_feature.FeatureSource.AddFeature(item2.GetShape(),item2.ColumnValues );
catch (Exception ex)
lLog.ErrorException(ex.Message, ex);
throw;
_feature.FeatureSource.CommitTransaction();
_feature.Close();
return _feature;
- Niels
Niels,
I have tested the shape file you provided, which feature type is Multipolygon, works well when I call feature.GetShape() method and display it, so I think it might be something wrong while importing the shape file to postgre server, we suggest you to use the PostgreSqlFeatureSource.AddFeature() method to import the shape file to postgre server.
Edgar
Hi I’m trying to import that shp file into postgres, but nothing is filled in the table (the user has insert rights)
Is there anything wrong with this code to upload the file??
It runs fine just NO data in the table.
string _shpFile = @“C:\GisData\t2\region.shp”;
ShapeFileFeatureLayer sff = ServiceRouting.ShapeLayerHelper.GetShapeFileLayer(_shpFile);
sff.Open();
Npgsql.NpgsqlConnection conn = new Npgsql.NpgsqlConnection(Utils.Connections.Connectionstrings.GetSqlConnectionPG());
conn.Open();
PostgreSqlFeatureSource sf = new PostgreSqlFeatureSource(Utils.Connections.Connectionstrings.GetSqlConnectionPG(), “region”, “gid”);
sf.Srid = 0;
sf.Open();
sf.BeginTransaction();
foreach (Feature item in sff.QueryTools.GetAllFeatures(ReturningColumnsType.AllColumns))
sf.AddFeature(item);
sf.CommitTransaction();
sf.Close();
Niels,
I tested with your file and code, it throws another exception, so I tried to remove the Srid = 0 from the code, and it works properly, 31 records were added to the database. Please try to remove the Srid = 0 from your code, I think it will work well for you.
Edgar
And here are the pictures I got.
002_001_code.zip (680 Bytes)
009_008_007_006_005_004_003_002_001_code.txt (448 Bytes)
