Geoserveropenlayers
I WANT ONLY ONE MARKER ON THE MAP,MARKER IS BASED ON MOUSE CLICK. I only ever want one marker added and if someone clicks more than once  I would like it to move the existing marker to the new position  AND   I WANT THE LAT LON POSITION ON MARKER LIKE POPUP  Can anyone help here is the code    SEE THE FILE ATTACHMENT BELOW FOR EDIT THE CODE THANK U
PLEASE HELP OUT OF THIS PROBLEM
REGARDS
RAMANAKUMAR
OPENLAYERS_MULTIPLE_MARKERS_BY_MOUSE_CLICK123.html (2.8 KB)
Hi Ramanakumar,
Thanks for your question but this might be a question for the Map Suite Web Discussion Forum as is seems you wish to create a web application.
For an example of adding a marker to the map, check out the Getting Started - AddAClickEvent sample application. If you have Map Suite Web installed you can find this sample at:
Start Menu - All Programs - ThinkGeo Map Suite Web Evaluation Edition 6.0 - VS2010 Samples - C# HowDoISamples.
