GeoTiff - How to change point projections
Greetings. I have a GeoTiff file in a WGS84 projection. I want to display this over a Google Map, but I'm having trouble figuring out how to convert the projection to the Google Map projection.
I tried overriding the LowerLeftPoint, LowerRightPoint, etc. but they are read only... However, the LowerLeftPoint.X, LowerLeftPoint.Y can be set..
The problem lies in that when I try to set them, LowerLeftPoint.X does not take a value, though .Y DOES take the value.
Is there a better way to change the projection on this?
Charley.
Charley,
Thanks for your post.
If I am not misunderstanding something, what you are trying to achieve is to project the GeoTiff file from WGS84 to Google projection (900913). Unfortunately, I do not think the MapSuite product can handle the projection fro Raster images up to now. Sorry for the inconvenience now.
