Get Bounds From GeoTiff Header
I have some user that have GeoTiff files that include the bounds in the file metadata. Is there a way to query the file for extents and apply them to the layer? Up until now I have been requiring users to provide a world file.
Also, would same method allow for using the skew parameters of the world file?
Damian
Thanks Damian,
You can try with
   GeoTiffRasterLayer geoTiffRasterLayer = new GeoTiffRasterLayer("../../../Data/GeoTiff/World.tif");
            geoTiffRasterLayer.Open();
            var hasBBX = geoTiffRasterLayer.HasBoundingBox;
            if (hasBBX)
                var x = geoTiffRasterLayer.GetBoundingBox();
GetBoundingBox will auto read the boundingbox information.
Frank
Hi Frank,
That seems to work okay, but I’m having a few other troubles in that I want to reproject the layer.
I’ve tried the following:
var y = layer.GetProjectionText();
layer.ImageSource.Projection = new Proj4Projection(y, 28350);
However, this clears the bounding box and subsequently produces an error. Once a layer is created, there is no way to assign the bounding box. So not sure what to do next.
Damian
Thanks Damian,
I don’t full understand this one. What are you doing is correct. We may need check the projection text first.
So you could try with
if(worldImageLayer.HasProjectionText)
Also console the value of y. Make sure it is a correct projection string. I you could send us the tif file set(include the twf file) and sample project that will be very helpful for us to understand the issue.
Frank
