Actually, we have a project in the Code Community that does almost exactely what you are trying to acomplish. The project is Dragged Point Style with Label. It shows the label with the distance compared to a reference point. You can slightly modify the DrawCore method in the DragInteractiveOverlay class and have the label showing what you want.
Thanks for your help, Val The sample seems get real-time draggedconrtrolPoint coordinates. it is different from I want. when i dragged each point and click button, i want to get all coordinates of controlPoints. (not just only draggedconrtrolPoint)
I have reviewed the source code of the sample, I found when the overlay draw label there is a check to make only the dragged point show label, you just comment out the 51th line code of DragInteractiveOverlay and then all point will draw label.
Hello, Like this issue, but I use TrackOverlay to draw a line shape. if I click "ok" button, how do I get all coordinates value? Could anyone give me any idea or sample? Thanks.
I am glad you figured out on your own. Also, do not hesitate to share your new findings to the public by showing your code in the post. That is if you don’t mind having some of your code public, of course. :-)
