Get distinct column values of a FeatureSource with FeatureIdsToExclude property set
I have a ShapeFileFeatureLayer which I set the FeatureIdsToExclude to exclude some features to be loaded. I also have a function that will get the distinct value of a column in that FeatureSource. The problem is it is getting the distinct values of entire shapefile column not the one with the excluded record. What should I do to only get the distinct column values with the excluded records?
    private List<string> GetDistinctColumnValues(ShapeFileFeatureLayer shapeLayer, string column)
            shapeLayer.Open();
        string query = "select distinct [" + column + "] from " + Config.Current.ShapeFileTableName;
            DataTable dt = shapeLayer.FeatureSource.ExecuteQuery(query);
            shapeLayer.Close();
        List<string> values = new List<string>();
        foreach(DataRow dr in dt.Rows)
            values.Add(dr[0].ToString());
        return values;
Ching,
 There are ways to get it:
 1. Use shapeLayer.FeatureSource.GetFeaturesByIds to get all the excluded features, and then loop and filter the features to make sure it’s unique
 2. Modify the loop statement to filter all the features to make sure the collection just contain the unique excluded features.
 Any questions please let us know. Thanks,
