GetBoundingBox intermittent exception
I get this exception around ~10% of the time I run the application:
MapSuiteSetup failedSystem.InvalidOperationException: The FeatureSource is not open.   Please call the Open method before calling this method.
   at ThinkGeo.MapSuite.Core.InMemoryFeatureSource.GetAllFeaturesCore(IEnumerable`1 returningColumnNames)
   at ThinkGeo.MapSuite.Core.FeatureSource.GetBoundingBoxCore()
   at ThinkGeo.MapSuite.Core.FeatureSource.GetBoundingBox()
   at ThinkGeo.MapSuite.Core.FeatureLayer.GetBoundingBoxCore()
   at ThinkGeo.MapSuite.Core.Layer.GetBoundingBox()
   at ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay.GetBoundingBoxCore()
   at ThinkGeo.MapSuite.WpfDesktopEdition.Overlay.GetBoundingBox()
This is the code it's running:
totalBoundingBox1 = layerOverlayForGraphics.GetBoundingBox();
Where layerOverlayForGraphics is LayerOverlay with 3 InMemoryLayers added like this:
                layerOverlayForGraphics.Layers.Add("inmem2", inMemoryLayer2);
                layerOverlayForGraphics.Layers.Add("inmem3", inMemoryLayer3);
                layerOverlayForGraphics.Layers.Add("inmem", inMemoryLayer);
I then tried opening all of the and still get the same error once in a while
                layerOverlayForGraphics.Layers[0].Open();
                layerOverlayForGraphics.Layers[1].Open();
                layerOverlayForGraphics.Layers[2].Open();
                layerOverlayForGraphics.Layers[0].Close();
                layerOverlayForGraphics.Layers[1].Close();
                layerOverlayForGraphics.Layers[2].Close();
I'm on Map Suite Wpf Desktop Full Edition 5.0
any ideas?
thanks
Thomas
Thomas,
 I just want to verify if this problem is caused by multi-threading cross calling, so that could you set layerOverlayForGraphics.TileType = TileType.SingleTile; and have another try. Please let me know your testing result.
James,
Thanks.  That seems to fix it.  I presume this change impacts performance?  What could be causing this?  Any other work-arounds?
thanks
Thomas
Thomas,
 I think when you use LayerOverlay, the default setting is MultiTile which using multi-threadings, to avoid threading crossing call, you can add lock() block the GetBoundingBox method.
James,
Thanks.  But why is that?  I mean it seems to occur only at start of the application.  Do I have to lock every time I call that function?
thanks
Thomas
Thomas,
 I think the reason that the error only occur at start of the application is that when you start application, it will draw tiles with multi-threading, each tile will open and close layer in worker threading, meanwhile you can layer.GetBoundingBox. After that you call layer.GetBoundingBox after each operation such as pan, zoom in/out finished, you can try to call it during the map drawing, I think it will has the same error.
 You don’t need to call that function every time, you can set overlay.LockLayerMode = LockLayerMode.Lock;
James,
I tried locking on the overlay and it still has the exception sometimes at the start.
I will try overlay.LockLayerMode = LockLayerMode.Lock;
thanks
Thomas
Thomas,
Could you try to do like this, override the GetAllFeaturesCore method as following code:
    public class CustomInMemoryFeatureSource : InMemoryFeatureSource
        protected override Collection<Feature> GetAllFeaturesCore(IEnumerable<string> returningColumnNames)
            Collection<Feature> returnFeatures = new Collection<Feature>();
            foreach (Feature feature in InternalFeatures)
                Feature newFeature = GetClonedFeature(feature, returningColumnNames);
                returnFeatures.Add(newFeature);
            return returnFeatures;
        private static Feature GetClonedFeature(Feature feature, IEnumerable<string> returningColumnNames)
            Dictionary<string, string> columnValues = new Dictionary<string, string>();
            foreach (string columnName in returningColumnNames)
                if (feature.ColumnValues.ContainsKey(columnName))
                    columnValues.Add(columnName, feature.ColumnValues[columnName]);
                else
                    columnValues.Add(columnName, string.Empty);
            byte[] wellKnownBinary = feature.GetWellKnownBinary();
            byte[] projectedWellKnownBinary = new byte[wellKnownBinary.Length];
            Buffer.BlockCopy(wellKnownBinary, 0, projectedWellKnownBinary, 0, wellKnownBinary.Length);
            Feature insideFeature = new Feature(projectedWellKnownBinary, feature.Id, columnValues);
            insideFeature.Tag = feature.Tag;
            return insideFeature;
<string></string>
James,
Thanks I will.  Am I doing something unusual for this to occur?
thanks
Thomas
James,
 I also sometimes get it when loading a shapefile and getting its bounding box
 ShapeFileFeatureLayer x= new ShapeFileFeatureLayer(dlg.FileName);
 rs = x.GetBoundingBox();
 thanks
 Thomas
Thomas,
 The code you provided is usual, but I don’t know there is any other unusual code to cause this problem.
 About ShapeFileFeatureLayer, I think you get another problem, because GetBoundingBox() of it won’t call GetAllFeatureCore, the stack-trace should be different.
 Just keep in communication to figure out the really problem eventually.
