GetBoundingBox with WMSRasterLayer
I have an application that allows saving of the map state (all layers, symbols, etc.) using serialization. Everything is working just fine. However, when I deserialize a WMSRasterLayer the GetBoundingBox method no longer works. It fails with the following:
System.NullReferenceException was unhandled
  Message=Object reference not set to an instance of an object.
  Source=MapSuiteCore
  StackTrace:
       at ThinkGeo.MapSuite.Core.WmsRasterSource.GetBoundingBoxCore()
       at ThinkGeo.MapSuite.Core.RasterSource.GetBoundingBox()
       at ThinkGeo.MapSuite.Core.RasterLayer.GetBoundingBoxCore()
       at ThinkGeo.MapSuite.Core.Layer.GetBoundingBox()
       at MapUtilities.frmLayerProperties.mPopulateLayerExtent() in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 668
       at MapUtilities.frmLayerProperties.frmLayerProperties_Load(Object sender, EventArgs e) in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 95
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
       at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
       at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
       at System.Windows.Forms.Control.set_Visible(Boolean value)
       at System.Windows.Forms.Application.RunDialog(Form form)
       at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
       at System.Windows.Forms.Form.ShowDialog()
       at MapUtilities.LayerUtils.SetLayerProperties(SilvicsTOCNode oNode, CustomWinformsMap oMap, Boolean& bTOCUpdateNeeded) in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Classes\LayerUtils.vb:line 697
       at GeoFrame.frmMain.mHandleFrameworkToolClick(ToolBase oTool) in C:\Silvics\VS 2010 Projects\GeoFrame\GeoFrame\Forms\frmMain.vb:line 853
       at GeoFrame.frmMain.ToolbarsMgr_ToolClick(Object sender, ToolClickEventArgs e) in C:\Silvics\VS 2010 Projects\GeoFrame\GeoFrame\Forms\frmMain.vb:line 731
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
       at Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick()
       at Infragistics.Win.UltraWinToolbars.ToolMenuItem.OnClick()
       at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.DoClickProcessing(MouseEventArgs e)
       at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.TextUIElementBase.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
       at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
       at Infragistics.Win.UltraWinToolbars.PopupControlBase.OnMouseUp(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.Run(ApplicationContext context)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at GeoFrame.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
I have no problem with GetBoundingBox after adding the layer to the map, only after it has been deserialized. The layer displays fine following deserialization.
Any ideas?
Steve
Steve,
 Can you proved a simple sample to us so that we can re-create your problem exactly, from the stack track information we cannot find out the exact problem in our core code, it just listed a little information for our code below:
 So we just know the problem is from the GetBoundingBoxCore method in the WmsRasterSoure class, we need to find out the problem from two ways:
 1, Core code, if the problem is from the core code we need a sample to re-create it, as so far I cannot re-produce your problem exactly,
 2, Your shape file, we have to determin your shape file is correct,
 Scott,
Scott,
Thanks for the reply. I have uploaded a sample project that should make it easy for you to reproduce the issue. I am using the full version of MS Desktop, 4.5.60.0. When you run the project, you should first click the step 1 button which will load a WMS layer. Then hit button number 2 which serializes the layer. Then hit button 3 to close the layer. Button 4 deserializes and loads the WMS layer. Then you can hit button 5 which calls GetBoundingBox (unsuccessfully) on the WMS layer.
Steve
SerializeWMSLayer.zip (60.7 KB)
Steven,
Thanks for your post and questions, your sample is critical helpful to identify the problem.
I think this should be a bug for the WmsRasterSource, I will report to our development team to get it fixed as soon as possible. For now, following workaround should work for your, sorry for the inconvenience for now.
Dim oWMSLayer As WmsRasterLayer
'***** Open a file stream to use for deserialization
oFormatter = New BinaryFormatter()
oStream = New FileStream(sFileName, FileMode.Open, FileAccess.Read, FileShare.Read)
oObjLayer = oFormatter.Deserialize(oStream)
oWMSLayer = CType(oObjLayer, WmsRasterLayer)
Dim newWmsDeserializedLayer As WmsRasterLayer = New WmsRasterLayer(oWMSLayer.Uri, oWMSLayer.Proxy)
newWmsDeserializedLayer.Open()
Dim oLayerOverLay As LayerOverlay = CType(WinformsMap1.Overlays(0), LayerOverlay)
oLayerOverLay.Layers.Add(oWMSLayer.Name, newWmsDeserializedLayer)
Yale,
Thanks for acknowledging the bug and thanks for the workaround, it works fine!
NOTE: You must also remember to add the layers to the new WMS layer, something like this:
For Each s As String In oWMSLayer.ActiveLayerNames
   newWmsDeserializedLayer.ActiveLayerNames.Add(s)
Next s
Thanks again!
 Steve
Steve,
 We have fixed this bug in the core code, please get the latest version from the DailyBuild of development branch, also we used your sample application to test the correction, your problem has been resolved correctly,
 Scott,
Thanks very much, works great!
 Steve
Steve,
 Thanks for letting us know your status.
