HI Thinkgeo,
Map.GetScreenDistanceBetweenTwoWorldPoints does not give correct result in pixels.
See attached code. If the distance is calculated before setting CurrentExtent of the map it gives 18.xxx (See attached code run in debugger to check distance value) and if evaluated after setting CurrentExtent then it gives 1086.xxxx
Anil
MarkerGetScreenDistance.zip (140 KB)
