Getting a bounding box of a Postgres Layer doesn't work
Hi Ben,
we tried out to display a Postgre Layer by getting a bounding box (see example code). It throws following error:
The layer doesn' have a bounding box
The same procedure with a shape file works very well.
Regards Joerg
Imports System
Imports System.Web.UI
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.WebEdition
Partial Public Class LoadAPostgreSQLFeatureLayer : Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As EventArgs) Handles Me.Load
        If Not Page.IsPostBack Then
            Map1.MapBackground.BackgroundBrush = New GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"))
            Map1.MapUnit = GeographyUnit.Meter
            Dim connectString As String = "Server=geo-04;userId=postgres;Password=geodata;DataBase=swisscom;" '172.16.2.6
            Dim postgreLayer1s As New PostgreSqlFeatureLayer(connectString, "hausanschluss", "id")
            postgreLayer1s.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1
            postgreLayer1s.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
            postgreLayer1s.Open()
            Map1.CurrentExtent = postgreLayer1s.GetBoundingBox()
            postgreLayer1s.Close()
            Map1.StaticOverlay.Layers.Add(postgreLayer1s)
        End If
    End Sub
Joerg,
 That’s a bug; we forgot to rewrite the HasBoundingBox property in PostgreLayer. Thanks for reporting! We will fix it in the upcoming version.
 It’s easy to work around though. You can call the relative FeatureSource to get the BoudingBox like
Map1.CurrentExtent = postgreLayer1s.FeatureSource.GetBoundingBox()
 Or you can inherit the PostgreSqlFeatureLayer class, override the HasBoudningBox property and make it true.  Both ways will work fine.
