Hi, I'm facing problems trying to get a screenshot of a map with a Google overlay. I'm using WriteableBimap.Render method that allow rendering an UIElement within a bitmap.
The method itself works great but I need to save the screenshot, so I need to convert WriteableBitmap into byte[] in order to pass it to a WCF service. To to do that, I must have access to WriteableBitmap.Pixels property.
Here is the problem, Silverlight throw a security exception when trying to access this property. The reason is simple : when we render a WriteableBitpmap of an element that contain data from an other domain, bitmap data is protected and Pixel property is not accessible.
My map contain a google map image, so I'm facing the security exception because I think you put the google url directly in the UriSource property of an image.
There is a way to override the method that create the google map image ? If it's possible, as a workaround, I will be able to use a WebClient to download the image, like in this post social.msdn.microsoft.com/Forums/en...fcbd2fe834.
Yohan.
