Currently, the API for ManagedProj4Projection allows you to get only the proj4 string, not the SRID. If you want to get the SRID from the proj4 string, you can go to spatialreference.org website where all the projections are listed.
The string is empty because in Spatial Reference, there is no proj4 string yet, only the SRID (.PRJ File). Let me do some research and see if there is some solution to this problem. Thank you.
. Yes, you can easily create the .PRJ file for your shapefile since it is available in spatialreference.org but this will not make your shapefile do the projection. Or, you can make the string for proj4 by yourself but you have to be sure how one parameter in PRJ translate to proj4
Yes, currently not all the PRJ strings can be converted to proj4 string and we are trying to figure out why. I will let you know when we know more. Thank you for your help.
Yes, with EPSG 27572 (NTF (Paris) / Lambert zone II), there is a proj4 associated with it, so this is going to work. I am glad you could find the proper projection for your country. Not all projections are properly documented and this is why some will not work with Map Suite. Thank you.
