I have two textblocks that I’m trying to populate with lat/long values as the mouse moves like doing Map1.MapTools.MouseCoordinate.IsEnabled = true; provides.
So I assign the mousemove event in the .xaml to this function in the code behind:
private void Map1_MouseMove(object sender, System.Windows.Input.MouseEventArgs e)
//code to update values
However, I’m unable to get the correct properties off of the MouseEventArgs e. For example, in a MapClickWpfMapEventArgs, there is a WorldX and WorldY property. In the MouseMove event though, there is no such property. Is there some specific ThinkGeo MouseMove function that I’m missing?
