Getting MapUnit from SRID
Hello ThinkGeo-Team,
what I need is a method that return the MapUnit I have to set to the Map-Control depending on SRID information. In our application the user can define the target SRID all the layers have projected to. Depending on the SRID I have to set the MapUnit for Map-Control to meter or decimal degree.
Is it possible to receive the MapUnit for Map-Control from parameter string of SRID?
Any suggestions?
Thomas,
I wrote an API for you; just take a try if you want:
private static GeographyUnit GetGeographyUnitCore(string projectionString)
     GeographyUnit geographyUnit = GeographyUnit.Unknown;
     if (string.IsNullOrEmpty(projectionString))
         throw new ArgumentException("Parameter is not valid.");
     else if (projectionString.IndexOf("units=m", StringComparison.OrdinalIgnoreCase) != -1)
         geographyUnit = GeographyUnit.Meter;
     else if (projectionString.IndexOf("to_meter=0.3", StringComparison.OrdinalIgnoreCase) != -1)
         geographyUnit = GeographyUnit.Feet;
     else if (projectionString.IndexOf("to_meter=", StringComparison.OrdinalIgnoreCase) == -1)
         geographyUnit = GeographyUnit.DecimalDegree;
     if (geographyUnit == GeographyUnit.Unknown)
         throw new ArgumentException("String is not correct.");
     return geographyUnit;
Hello Yale,
 thanks for your code. This is what i need.
 Thomas
Thomas,
 OK, Thanks for letting me know your status.
