Getting Rotated Coordinates
I have a situation where i have rotated all of the layers on my map. As is my understanding when i rotate the layers the x and y coordinates remain the same.
When i Use the map click event and get the e.worldx and e.worldy values it's returning the x and y coordinates without taking the rotation into consideration.
Can anyone help me understand how i can get the map coordinates whilst taking into consideration that the projection has been rotated about a single point?
 I thnk i fugured it out in the end, i just took the coordinates that the map was returning and reversed them in order to match the coordinate systems.
 I use shape rotate rather than applying the projection to the actual layers as i’ve never been able to get the to function as i wanted.
   Friend ReadOnly Property ClickedPosition As PointShape
         Get
             Dim dtem As New PointShape(SelectedPointOnMapX, SelectedPointOnMapY)
             If RotationTracker.isMapRotated = True Then
                 'We do a reverse rotate on the clicked point because the coordinates coming back from the map are in a non rotated state
                 'The layer the shape exists on is rotated.
                 'when we rotate the shape layer we move the coordinate system as well as the shape.
                 'when we click the map it provides coordinates that ignore the rotation
                 'If we reverse the coordinates back by the angle the shape layer is rotated by then we are ultimately matching the two coordinate systems
                 dtem = New PointShape(RotationTracker.ReverseRotate(dtem.GetWellKnownBinary))
             End If
             Return dtem
         End Get
     End Property
 Public Class RotationTracker
     Public Shared Property isMapRotated As Boolean
     Public Shared Property Angle As Double
     Public Shared Property Proj4 As New ProjectionWithRotation
     Public Shared Property RotationPointX As Double = 8.31589444444444
     Public Shared Property RotationPointY As Double = 49.0127777777778
     Public Shared Function Rotate(item As Byte()) As Byte()
         Return RotateMapLayer(item, Angle)
     End Function
     Public Shared Function ReverseRotate(item As Byte()) As Byte()
         Return RotateMapLayer(item, -Angle)
     End Function
     Private Shared Function RotateMapLayer(item As Byte(), angle As Double) As Byte()
         Dim Shape As BaseShape
         Dim feature As Feature
         Dim RotationVertex As New Vertex
         Dim rotationAngle As Double
         rotationAngle = angle
         _Proj4.Open()
         RotationVertex = _Proj4.ConvertToExternalProjection(RotationPointX, RotationPointY)
         feature = New Feature(item)
         Shape = feature.GetShape()
         'rotate cant handle negatives, it rotates in a counterclockwise direction
         If rotationAngle < 0 Then
             rotationAngle = Math.Abs(rotationAngle)
         Else
             rotationAngle = 360 - rotationAngle
         End If
         Shape.Rotate(New PointShape(RotationVertex.X, RotationVertex.Y), rotationAngle)
         Return Shape.GetWellKnownBinary
     End Function
 End Class
Hello Aaron,
 I’m glad it’s working for you now, for the coordinates rotate problem, if you apply the same projection which your map is using to the layer which contains the points, it will taking the rotation into consideration.
 Any way, the way you are using is no problem too.
