Getting the item a user clicked on from different layers
I'm currently working on a solution where i provide the ability to open files from my map, i add icons to the map relating to the file that needs to be opened in the form of a pointstyle.
Each file has it's own layer with it's associated file icon applied.
I want to loop through each layer in the overlay and determine which icon was clicked on. I currently have the following code:
 Dim overLay As LayerOverlay = Me.map1.Overlays(Overlays.DataFileOverLay)
        For Each Layer As FeatureLayer In overLay.Layers
            Dim clickedPointShape As PointShape = New PointShape(ClickedPosition.X, ClickedPosition.Y)
            Dim selectedFeatures As System.Collections.ObjectModel.Collection(Of Feature) = Layer.QueryTools.GetFeaturesNearestTo(clickedPointShape, GeographyUnit.Meter, 1, ReturningColumnsType.AllColumns)
            If selectedFeatures.Count > 0 Then
                Dim dtscenafile As DTScenarioDataFile = selectedFeatures.Item(0).Tag
                Dim rectang As RectangleShape = selectedFeatures.Item(0).GetBoundingBox
                If rectang.Intersects(clickedPointShape) Then
                    'raiseevent
                End If
            End If
        Next
The calling of GetFeaturesNearestTo in the code above always returns a file as each file has a layer of its own. To ensure that we a file that is in the position clicked i added a test for intersects but unless the user clicks on the exact point that the image was added then this always returns false.
How can i determine if the user has clicked on the point style on a layer if i have icons spread across many layers.
Aaron
Aaron,
Following 2 solutions are provided, please take a try, and hope it helps.
First, try to use the Contains API instead of Intersects.
Second, try to give it a buffer with the tolerance given before doing the Intersects. For example, search out icons within the distance of 10 meters instead of trying to get the exact point.
Dim queryPointExtent = clickedPointShape.Buffer(10, 8, winformsMap1.MapUnit, DistanceUnit.Meter).GetBoundingBox()
If rectang.Intersects(queryPointExtent) Then
     'raiseevent
End If
If you still have problems, it would be nice if a sample could be provided to recreate your problem.
