Google Map Overlay not lining up with Shapefile
I am using MapSuite 4.0.
As per the attached screen capture, the shapefile is not lining up with the google map overlay.
I have followed the examples for projecting the shapefile.
This is the code I am using:
//Projection to go from Geodetic (Longitude/Latitude) to Google Map projection (Spherical Mercator).
//Geodetic projection (Longitude/Latitude).
roadsLayer.FeatureSource.Projection = proj4;
Any suggestions on how to get the two layers to line up?
Elisa
Are you sure that your shapefile is really in EPSG 4326 projection (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs)? Can you check the projection information with the shapefile, the PRJ file? It has to match this:  spatialreference.org/ref/epsg/4326/
 If you have no projection information. Make sure with your provider what exact projection your shapefile is in. Thank you.
Val:
I have located the projection information.  However, the code is not in any of the lookup files for MapSuite.  How do I add it in?
Code:  SR-ORG:6706
<style type="text/css">
</style>North American 1983 (CSRS98) Canada
Well Known Text as HTML
GEOGCS["GCS_North_American_1983_CSRS",
    DATUM["D_North_American_1983_CSRS",
        SPHEROID["GRS_1980",6378137.0,298.257222101]],
    PRIMEM["Greenwich",0.0],
    UNIT["Degree",0.0174532925199433]]
Human Readable OGC WKT
Proj4
+proj=longlat +ellps=GRS80 +no_defs
OGC WKT
GEOGCS["GCS_North_American_1983_CSRS",DATUM["D_North_American_1983_CSRS",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
.prj file
GEOGCS["GCS_North_American_1983_CSRS",DATUM["D_North_American_1983_CSRS",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943295]]
ESRI WKT
Proj4
OGC WKT
Elisa
</style>
Please, refer to this post: gis.thinkgeo.com/Support/Discussion...fault.aspx
